Power source.
  • Thread starter Thread starter Peddler 356
  • Start date Start date
P
Peddler 356
Guest
I just bought a 98 Ford Ranger and would like to know (without butchering a wiring harness) where one could pull a hot for the radio. This truck ain't quiet like my old 79 Chevy.
Thanks
Jim <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
The Peddler............
</p>
Thanks
</p>
Battery is my first choice. Second would be either tapping the cig lighter wires or use a fuse tapper in the fuse box.
Wm. Warlock "671 in Va"
Rollingradios@aol.com
Nat. Rep for XForce/Magna Force Customer Service and Support
</p>
</p>
Just a note for you or anyone using a cigarette lighter for power--I used mine for a while in my Jeep cherokee and It never worked right because the ground was insufficient. I was seeing about 5 watts out of a galaxy 88. Thats how bad the ground was. Just make sure that the radio is properly grounded. I use the seat post bolt for a ground -and I also went to the fuse panel.
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=daddy1rabbit>daddy1rabbit</A> at: 11/10/02 9:28:34 pm
Thanks for the replies.
Doc, I was going to use a blue flame heat wrench untill the wife caught me. Looks like the Battery is 1ST choice with everyone. That it will be.
Thanks again
</p>
Thanks again
</p>
RF, thanks for the offer. I live in Waco, just south about 100 miles. If I ever get off when there is still daylight, I will get the thing hooked up. Right now I running a stock 25LTD classic pluged into the accessory power port with a K40 mag antenna. I really miss my Magnum 257 and heater, but it will come.
Thanks again
Jim<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
</p>
Thanks again
</p>
Thanks
</p>
Run the direct "power" line straight to the battery. Use the same gauge wire, or heavier, to the battery. Run the ground to a bolt, maybe one of the seat bolts. Any bolt that is going into the body/frame of the vehicle. I have found this works the best. You can also run the ground straight to the negative post of the battery if you like. Just a couple thoughts.
