golden eagle mark 3 no lsb
Bill -
It looks to me like the carrier oscillator V1a (12AX7) is dead in the LSB mode, or the Mode Switch has an open contact in the LSB position. Since the oscillator is working in AM and USB, the tube is ok. You can check for oscillator output by putting a scope probe on the side of C6 that is connected to the mode switch. If no oscillation in LSB, check crystal CR2 (5.6480 mhz), and make sure tuning cap C2 isn't shorted. If these check OK, then check the contacts on the mode switch in the LSB position. Check all the solder joints in the area too. Good Luck.
- 399
thank you
Bill -
- 399
ok i will check it out. thanx 4 the info.
73s kj4mqa bill
