WHICH BEAM ANTENNA IS WORTH PUTTING UP??
I'm glad you fellas like your Signal Engineering antennas. I've built several quads over the years and they've always done well.
Signal Engineering does have some flat-out wrong info about the way antennas work in general though (such as no f/b on a directional antenna with no reflector!), so take their "theory" with a grain of salt.
Rick
Rick
Forget the theory. I am going off Real World experience. My Signal Engineering 6 element quads WORKS...
Well, that's good, and it should. It's hard to make a quad or delta loop not work, honestly. They're great antennas, and if you don't mind dealing with a skyhook that has 3 dimensions, they're hard to beat.
I did email them (politely) about the misinformation on their website a couple of years ago. Never heard back from them and they haven't changed it.
Jcox$$$,
The date and time sent can be found near the bottom of each post. It is in light grey and a little difficult to see.
Welcome to WWDX. (y)
