Flex Radio SDR-1000 on 11m
You have to send into Flex-Radio with a valid MARS license. They send you a firmware update (I think that's what it is). I talked to a fellow MARS licensee who had to go through this procedure. To my knowledge, no one has "hacked" it.
thanks, that was what i was starting to see from poking around in the software. shame i really dont like having limitations on my gear. you never know when you might need to transmit out of band especially during an emergency.
941
I read that only FLEX models have firmware, the SDR-1000 does not use firmware.
The PowerSDR is open-source, so it should be no problem to find the frequency limits.
ok so now there is hope. i just hate having a radio that is limited. i have heard of some of them being used out of band i just cant figure out how.
941
941
27.555 usb coming alive with skip isn't generally classed as an emergency.
Reactions: wavrider
I think maybe he thinks folks here will go QRZ on him.
941TX, I have my ticket and ALL my rigs TX out of band.
If you figure it out, lemme know.
I'm considering a Flex 3000 and would use it nefariously.
come on guys, i am just tring to keep from getting flamed from some do gooder. most radio related forums and a question on how to do 11 meter mods is usally followed be several flamed replys. i am just tip toing through the thorn patch by habit.
941Texas
Reactions: jazzsinger
just a update on the whole 11 meter tx. i found a older version powersdr on the web that is tx enabled. works great on all bands.
theres gonna be screaming,...
and wailing,...
and gnashing of teeth,.................. on the ZED :cursing: :pop: :cursing:
