RADIO SHACK HTX 10
TonyV225
Apr 18, 2005
5,824
331
143
Wisconsin
I have a local with 2 of these in the boxes brandnew never used he wants to throw in on a trade deal on my KLV 550 base amplifier I have forsale. What are these worth or what was the cost from radio shack also can these be frequency expanded and is it worth doing?
Also I read an article that a guy claimed these were made for Radio Shack by Magnum and there basically a Magnum 257 and others were saying they really like theres for 10 meters. I thought I had the frequency expansion modification in a book here somewhere Im not sure what to do but it is an option as far as a trade.
Any info would be helpfull Thanks.....Tony
Radio Shack closed them out for under $50, I bought the local store's display radio for $25.As far CB/Freeband mods I don't know.I've read the mods but never tried it.Some people say they work others say they don't. I do know they are a good 10 mmeter radio.
I doubt Magnum built them for Radio shack and I doubt Magnum builds their own.It's more like Radio Shack and Magnum paid the same company to build them to their specs.
I was wondering about the builder of it I know uniden did some of there CB radios but Im not sure about the others like my HTX 212 mobile 2 meter radio I need repaired if I knew who was responsible for its build I would know what or who to referr it to but AES and Burghardt Amateur all play tupid or the I dont know game when it comes to the who built them topic.
I believe it was a guy on a EHAM Review that said Magnum is who built the HTX- 10
I searched the web radio shack htx 10 and found some reviews and there is a mod to expand the freq. from 26.000 to 29.900 as far as what is good and what is not i have not played with one yet. Sorry i dont have more info for ya
If I remember correctly, there were certain serial numbers that could NOT be modified.
I have had several of these. The only way to mod it is to put a cpu from the 257 in it. Radio Shack did not want these on 11 meter at all. They are a better ten meter radio than the 257, they will tune in 1 khz steps all the way across the band. The 257 will tune in 10 khz steps only, pain in the ass on 10.
Rich
yeah I have to decide what I want to do now like I said there brand new in the boxes. I have a mod here where you just add a resistor.
HTX 10 MOD 25.150-29699mhz 1.open radio look up on front face board if you look very carefully you will see 2 solder pads where there could of been 2 pins for a jumper plug (like the 2950's)you will see one side goes to a smd. and the other goes to a ground island solder a resistor 10 ohms across pads (the resistor is brown black black gold 1/4 watt) Now put the radio back together and hold fun' and button 2 in while turning on .the radio will have a 40 channel display on right of freq display 1-40 press 2 to change bands along w/ lower left button' THERE is NO fine mod for radio due to missing components. and you know how to turn up amc and alc in the rear.
Radio Shack had a ham version and a cb version of these radio's. Neither would mod to talk both 11 and 10m without a chip swap. Unless your a ham I would leave them alone and keep your amp.
Well thats why the guy does not want them anymore hes had them sitting in a closet for a year now he bought them on a closeout at a local radio shack and then said he isnt going to mess with them and he knew that at present I my wife and 2 of my teenage kids are licensed Amateur operators so we may get use out of them.
I was thinking about it but then was wondering if these could be opened for M.A.R.S. frequency expansion but its not looking to good as far as that goes.
The HTX-10 is not a CB radio! [SIZE=+1]The radio [/SIZE]cannot[SIZE=-1] [/SIZE][SIZE=+1]be modified to go below 28.000 Mhz. So if you are thinking about buying one and using it to go down to 11 meters.... forget it![/SIZE] There are several mods floating around the net but it seems that none of them work on the HTX-10. There are several versions of this radio sold by different companies some of which use a different CPU which will allow the radio to go "out of band". If this is the case then the CPU in the HTX-10 would have to be changed, not an easy task as it is soldered to the board. The HTX-10 has been on the market for a few years now. If there was an easy way to extend the frequency range I'm sure someone would have found it by now!
RADIO SHACK
It requires a CPU swap. Years ago I had one thinking it was just like all the others it resembled. Sold it. Wish I had it now :)
The CB version (TRC-485) can be expanded to cover 25.165-29.655 MHz.
I would love to find someone with one new in the box that i could snag
would use it just for 10 meters . i already have a rci 2950 to do both.
KD0GOJ
