Mobile Antenna Stinger
  • Thread starter Thread starter Deleted member 337
  • Start date Start date
D
Deleted member 337
Guest
Does it matter which end of the of the stinger that you cut in order to get the best possible swr? I have always seen people cut the bottom off a little at a time, but can you cut it off the top instead?
Doesn't matter, you can even cut it in the middle if it needs to be really short.:lol:
No you can cut from either end if your stinger does not have a corona ball but if it does it only makes sense to cut from the opposite end.
