****Proper DXCC map for 11meter by QRZ11.COM****
Several error's on the map!
Where's 231 located? St. Peter & St Paul Rocks.
There are (2) 236 spots.
285 is wrong - should be 258
No spot for 285 which is Fernando De Noronha isl.
274 wrong location on map.
Uuuhhhh
Uuhhh!!!
I'll have to check this...!
TNX for telling me DXman.
will update the map a.s.a.p
73's
Mike
Hate to bother you again.......but, on the right side of the map you have showing 317 as Byelo Russia, this should actually be Belarus and all new maps/globe's will show this. Belarus received it's independence in 1991
Also need to put the #317 where Belarus is located.
While your at it, could drop in the #285 on the map - it's missing.
I was noticing also that 231 on the map is the Portuguese name for St. Peter & St. Paul Rocks, all the DXCC list that I have seen are showing the latter. My National Geographic map also shows it as St. Peter/St. Paul Rocks.
We would love to have you in our team.
Hi DXman
TNX for the map-info again... !
We will be right on it.
73's
Mike
Div 91
Whoops......guess what?
Check out #91 - there are 3 of them on the map!
Jip!
Div 91 is quite big.... Islands ect.... So that no one gets confused we put the 91 more then once in the map .
Just for you DXman I have put a frame around 91 div. :-)
Regards Mike
P.S. TNX for your help.
Well Mike, buy you putting the frame around the 91, I learned a couple things!
I now know that New Guinea is part of Indonesia and that 101 div (Papua New Guinea) is independent, I thought they were of the same country.
Then I got to looking and I see where a large part of Borneo is owned by different countries, mostly being Indonesia. I didn't know that Indonesia was that big!!
Thanks, I'll leave ya alone now........
TNX
No problem DXman,
I have to thank you for helping us.
TNX to you we corrected the few errors on the map.
We are currently working on a new map. I will put the phrase "with the help of DXman" on it.
73's
Mike
