connex 33tlm3 display help ????
johnecashflo
Wish I Was Here
Mar 26, 2007
134
4
28
INDIANA
has anyone out there figured out how to get the pics or mp3 player to work in these darn things..maybe thats why the radio is discontinued...
I don't know if the size limitation or pic format is the problem you're up against, but this is posted over at CB Tricks:
Known Limitations
The USB slot on the front panel will only handle 1 GB - If you exceed this with a larger thumb drive the unit will shut down and you have to remove power at the rear panel to revive.
The SD slot will only handle 2 GB Maximum and the same is true above.
Also the pictures must be in jpeg format to display on the TFT screen.
Connex CX-33TLM3 Service Manual
thanks for the reply ive tried all the stuff at c.b. tricks..any other help from someone who might have had or has one of these radios..or worked on one ...thanks
