IN LINE FILTER
doctor
Supporting Member
Aug 1, 2006
1,036
80
58
82
indiana
On these in line filters do they connect on each end by plugging in the phono cable from the pc then another phone cable to the xcvr??, if so what model number and where to buy, obviously am going to try one.
Tnx
DOCTOR/795
Tnx
DOCTOR/795
:confused1: What kind of inline filter are you talking about? Lowpass TVI filter perhaps?? Nothing connects to your PC or uses phono cables if that is the case. They use regular SO-239 connectors. Maybe you are talking about some sort of audio filter/EQ unit?? More info please. Tell us what you are talking about.
i'm a little confused too.
i "think" he is refering to a soundcard interface with an opto-isolator.
I've got a feeling it's probably an audio cable thingy too. Several ways of going about that, the commercially available one such as from 'RigBlaster', etc, or a simple isolation transformer and maybe a 0.01 cap will also work in most cases. A five gallon bucket of torroids is nice too...
Probably one of these.
It will require the use of phono to 1/8 mono jacks to connect to a pc, I use one for recording from radio to pc.
Ground Loop Isolator - RadioShack.com
FILTER
I was refering to an audio filter, and have gone to ratshack as described and purchased one, I should have been more specific, thanks for info guys.
DOCTOR/795
Audio filter at Radio Shack? What do they have in the way of audio filters?
DOCTOR/795
This is what I figured you were talking about
Audio Output Transformer - RadioShack.com
That is an audio output transformer, not a filter. I believe it converts 1000 ohms down to the 8 ohms required by the speaker.
The 'Shack' used carry three 'filters'/transformers of this type. One was as shown, one was a 600/600 ohm, and I can't remember exactly what the third one is/was. They came in very handy in a number of ways, interfacing radios/computers was only one of them.
One of the earliest PC/radio interfaces was only a transformer (one of the above) and a 0.01 ceramic disc capacitor in series with one of the leads. Which transformer? Just depended on if you knew what the impedance of the inputs/outputs were, sometimes 'we' didn't, so whichever one seemed to work okay. (The one shown worked good, typically because it had more than one 'tap' so could be 'adjusted' some.) That 0.01 capacitor was sort of for the more difficult cases of RF. If you were really 'bothered', you could go to a 0.1 cap, but it had some 'benefits' that didn't always end up with very much 'fidelity'. [A very common way of interfacing in the "early days" of computer SSTV, JV-FAX, etc It worked!]
Another thing that you had to watch out for was 'grounding'! Computer sound cards are/were usually NOT operated at zero 'ground', they 'float'. If you ground them, you just crashed the computer :). No 'blue screens', they just turned off. That was so much fun the first time it happened! Or maybe the first several times??
Also don't expect much 'power' handling ability with any of those transformers. Not something usually worried about with audio circuits, but something to think about.
And like most other things dealing with RF, a five gallon bucket of torroids really does come in handy!
Have fun.
If you're really desperate, you can build one'a them interfaces into a 25 pin RS-232 port connector. But who uses them things any more??
