data transfer cable for FTM 350R
butser42
Nov 25, 2010
2
Is there another cable that can be used to install firmware? The CT-140 at HRO is 55 bucks. I don't need anything but data transfer to upgrade firmware. I think the CT-140 is for aprs as well.
:headbang
You can build your own. The cable pinout is in the manual. Make sure and get the latest manual online as there was a misprint on this topic in the original.
:headbang
Hamcity $39.99 for the software and cable for USB.
Sent from my DROIDX using Tapatalk 2
You can use the RT Systems cable (USB-81) $30 alone or $49 with the programming software. Here is the link: cheap jerseys The software makes easy work of entering frequencies and settings. Also makes it a breeze for swapping files for when you travel.Jerseys for Cheap Hope this helps.:thumbup:
