looks like 2 power supplies wired in parallel, gives more amps same volts
The higher rated amp will "tote the load" so to speak. The owner has been enlightened and offered thanks for someone pointing this out to him in a kind way as he did not realize that.
He has since removed the 5 amp supply.
Well then you will have to take that up with gamegetter.
yes, 2 power supplies with the SAME output would give you those results.looks like 2 power supplies wired in parallel, gives more amps same volts
ok then what will two power supplies with different rated output give you?
How many amps will the setup in the picture produce?
thanks in advance
What ever the bottom ps is rated at.
A better question would be, how long would that set up furnish any power at all?
Wait a minute...that's not what gamegetter just said.
