cobra 29 chrome no audio out
rickf
Sugarfoot
Jan 28, 2011
3
San Bernardino ca
It turns on lights up all the switches work. gets great reception with the wilson antenna. Just went out and got a cobra power mic hook it all up to my lil car and got the ole lady to turn on the base unit and bang no output she can hear me key up but nothing else. Can one of you guys help me out with this problem
Did you put the stock mic back on it and try it again?
yeah It didn't come with a stock mic I went to the local shop and bought a Cobra high ger power mic and had them hook it up and test it. It worked so I took it home and hooked it a nothing is comeing out .
I think that radio has a dynamike, is it turned all the way to the right or to the left? Crank it all the way to the right if it is to the left and that should fix you up unless something is wrong with the mic circuts.
Long shot here, but if you're mounting the radio in a bracket and tightening the mount knobs way down, it could be pulling the audio chip away from the circuit board. Problem with that theory is that the receive audio would be gone, as well, and you stated that you still had good receive. Only other thing I can think of is that you have a connection issue at the mic jack that did not show up on the test bench.
Thanks for the reply to my post I will be taking it back this week to have the same dude look at it if he can't fix it he can hook me up with something else im sure. Hes a pretty good dude...
