Galaxy 959 mosfet final or not
dssshotgun
Dec 27, 2010
6
82
I have a 959 and the driver and final has no numbers or marking as to what they are.. How do you know what is in it? It was made 7\10. I check and all the parts are still in it that was to be removed when replaceing 1969 with a mosfet.. Any help appreciated!!
Thanks
Frank
Others can confirm this, but if it's manufacture date is July 2010, it is already equipped with a Mosfet.
Notice the manufacture date on this 959 - 9/07. Now a quote from the review:
http://www.cbradiomagazine.com/Radio Reviews/Galaxy DX 959/Galaxy DX 959 Review.htm said:
These radios used to come equipped with 1969 finals but now are being made with the mosfet transistors. I did have a chance to use one with the newer transistors and found that the mosfet equipped radios will have around 5-8 watts more peak output on average.
Yeah you're good to go
And mosfets are better. More power and bigger swing = LOUDER = better for barefoot or driving an amp either one.
With a proper peak & tune that 959 can do around 35 watts p.e.p. May want to then add a heat sink to the back.
Good luck
Good luck
Mosfets aren't louder, that's just silly. Mosfets do not handle abuse and heat like the 1969s do.....but they do more peak watts.
Thanks
Frank
Mosfet driver and final.
