G5RV Orientation
richardyoo
Aug 18, 2009
17
I plan on putting up my G5RV antenna tomorrow and I was wondering if there was an opinion to which direction it should be hung?
I'm in Houston, TX so I'm about a bit south but otherwise in the middle of the US...
I was going to hang it North-South... but now I'm wondering if it should be East-West? Or if it mattered at all?
N5YOO
What bands, or what's the lowest band you'll be using the thing on? They really don't become very directional until something like a wave length above ground. They get 'sort of' directional at about 1/2 wave length above ground.
A lot of things affect the shape of an antenna's radiation pattern, but height does make a difference.
Mine runs NE-SW at a height of 9.144 m. (The ladder line which runs verticaly from the intersection of the two poles is 30' (9.144 m) to the balan.) Works equally well in any direction. I eventually would like to move it further away from the house though.
Mine runs NE-SW at a height of 9.144 m. (The ladder line which runs verticaly from the intersection of the two poles is 36' (9.144 m) to the balan.) Works equally well in any direction. I eventually would like to move it further away from the house though.
:oops:Actually, 36 ' = 10.9728 m
I ended up getting the antenna about 30feet in the air with the ladder line coming straight down... its pointed NE-SW... we'll see how it does.
I actually don't have a band preference - this would be my first HF antenna... should I have a preference?
Listen a lot for the answer.
That antenna won't have much directivity on the lower bands but will have a pattern on 40/20/10. Maybe someone can post an EZNEC plot for you.
Rather than fret about whether a simple antenna will "work" if installed North/South, or maybe North-northeast by east/South southwest by west, or if it's at 28 feet or 32 feet, or any other such details -- just put the darn thing up and try it. And take notes. Learn from doing.
That's precisely what I did, by utilizing the available trees to hang it from.:wink:
