Marconi's Recap for Signal Reports #17 thru #48
Marconi
Honorary Member Silent Key
Oct 23, 2005
7,230
2,391
343
Houston
This recap took the best signals only...for a small group of regular contacts among all reports listed on my recent Signal Reports #17 thru #48.
I added up the signals for each antenna and divided by the number of contacts for an average of the best signals.
My Gain Master and my Sigma 4 tied for 1st place at 7.9 Sunits average signal with my Wolf .64 in a close 2nd at 7.7 Sunits.
View attachment Recapped Signal Reports #17 thru #48 040711.pdf
so the gain-master and the sigma 4 tied for first place .......
where they at the same height for feedpoint or tip height ?
thank you so much for the effort you put into getting and sharing your results with us eddie :)
I was not tracking the height here. The heights are however, noted on all 48 reports for anyone to check. I used two P/U poles that are similar and I pushed them up as high as I could, given the situation at the time. Most of these tests were done with the antennas at the same mounting height.
Booty, all I did in the recap was to go thru my reports from this past fall and spring and pick out the best signals for each of the guys I choose as regular contacts. I listed the signals under the antennas noted at the top of the columns for each contact. This comprised about 5 months of work that I recapped together, and the focus here was on the best individual signal for each guy, each antenna, and not the averages for each report...as I posted before.
