Merlin Base Up Close and Personal
In what way is this antenna an improvement over the original? Does the coax connector make it get out better?
The odd part of the starduster was how the coax fed in there, inside the mounting pipe. What happens if the end goes bad? Well you then would have to disassemble the whole damn thing to fix the coax PL 259 end!!!
If I where given a starduster, I would cut it up and make a few scanner antennas out of the pieces.
..and as much as metal prices go, antenna prices will go up even further if market trends upward.
I think im happy with my A 99.it survived a tornado and works fine
Reactions: undertaker
