bullet proof amps
tvrc18
178
5
28
were can you buy a bullet proof brand amp? I see them on amature linears page but see no way to order or inquire?
I have a Bullet Proof 2 pill with 1446 finals. It's an exellent AB amplifier and has the best "variable" SSB delay I have ever seen. There is a VR pot on the back of the amp that lets you set the delay time. AMA is the only place I ever saw selling them. Sparkys cb shack did sell them at one time but I think they are no longer selling them. I will see if I can locate them for sale on the web.
I have a 2 pill 2879 I built to which I incorporated the the same delay but I had no idea there was such an amp in production at the time I developed mine.
ps: mine is on the front of the amp because there was already a hole drilled there.
I saw that site but see no way to email or order, what's up with that?
Just my theory, but: if they provide a means to order, somebody would probably buy a "Bulletproof" amplifier.
If somebody bought one, he might blow it up, thereby proving that it wasn't bulletproof to begin with.
Therefore, no way to prove false advertising! Ta Da!!
I ended up buying this amp and have a couple of questions. Will a stock HR 2510 over drive this amp. I will mainly be on usb. Should I turn down the alc for less output from the 2510? It says in the add it has 2879's but the only info I found shows 1446's. I know that would over drive them.
That depends on a couple factors, such as what kind of overdrive protection the amp might have (if any) and the number of transistors.
Personally I wouldn't hit it with 25W+ if it's running a pair of SD1446s. 12W PEP is the absolute highest I would go, so yes you should turn it down.
  • @ Spanish:
    Where do i upload schematics
