Everything 'drifts' to some extent, especially while 'warming up'. That goes for those test equipment devices too. Solid state stuff tends to 'drift' less than the older "hollow state" stuff, but it's still there. Drifting is a normal thing to happen with heat. That's one reason why crystal ovens are used in more expensive devices.
Depending on how/where a radio is used, after some use you tend to have a 'feeling' about 'when' your radio has settled down to it's normal state of accuracy. Before then, you more or less have to 'wing it', not get too agitated if someone tells you you're off frequency.
Adjusting, or calibrating frequency accuracy isn't something that's done very 'accurately' by ear unless your radio is specifically designed to be 'tuned' that way. Even so, you are only going to get 'close'. And the biggy is just how accurate is your frequency standard? And how 'wide' is the mode you are using to do that calibrating?
If you have a frequency display of 18 digits (yeah, right
) you'll notice that the last several digits are changing almost continuously, and that's about as normal as you get. And then you get to ask yourself, just how accurate is the person complaining about how far off frequency YOU are.
The bottom line is that if you don't have the equipment to do that checking, don't try calibrating the thing. The chances of you getting it 'right' are very slim...
