are gamma matches excellent lightning protectors ?
  • Start date Start date
Gamma matches do offer added lightning protection however, several conditions have to be met before you gain any benefit. The radiator must be DC grounded, the antenna must have an extremely good earth ground system and a quality lightning arrestor should be installed on the transmission line just prior to the cable entering the building with its own ground.
The radiator must be DC grounded because otherwise it is likely lightning will still see the path through the gamma match as the least resistance. Most stock gamma matches have a DC break down voltage over 10,000 volts. Many aftermarket models will handle over 50,000 DC volts before flashing over.
In comparison to the voltage of lightning, 50,000 volts is more like a double A battery. Lightning will easily exceed this by many many times. The trick is to keep the voltage drop across your ground system below the breakdown voltage of your gamma match. If the ground is sufficient, it will sink the majority of the current to ground without flashing over the gamma match.
There will still be a pulse of current for a fraction of a second as the gamma match capacitor charges. Many broadcast transmitters can handle this pulse especially if the FPA uses a tube. Nearly every receiver will still suffer damage without a gas discharge type lightning arrestor. If you run an amp, you may still have problems because the discharge tube will have to handle the RF voltage of your amp. If you want to save the rig too, you may need another low power arrestor at the back of the radio.
None of this is a guarantee you will survive a direct strike unscathed although broadcast stations survive these types of strikes in many cases. The gamma match helps, but only if everything else is done correctly first. It does this by providing DC isolation to the transmission line and will still require an exceptional ground system to pull off any real lightning protection.
A gamma match does nothing a simple 100pF HV capacitor in series with the feedline does. As you say, it ONLY works if all other things are taken of as well. that applies to any type of feed. I still would not say that a gamma match helps for noise nor in lightning protection all by itself.
what took you so long SW ?
you been on a trip to brazil ? :lol:
ok since we got into transmission lines ....... i got another odd ball question . :confused:
since lightning will follow the path of least resistance ....... if a station has a copper ground rod in the ground 1 ft from the mast with multiple heavy solid copper conductors between it and the mast , and the antenna is solidly grounded to the mast ...... does 8X coax with its smaller diameter/less surface area shield offer even a slight potential for not damaging equipment inside as much compared to larger coax like the 400s and such ? i try to always disconnect my coax from my meter if a storm is being forecast or if i'm leaving overnight or for more than a couple hours if something is forecast or looks possible .... and of course i'm not perfect at that .
and what would you consider to be "an extremely good earth ground system" for a CB'er ? is one ground rod enough ? or is it just better than nothing ? fortunately we have pretty good earth/dirt here in Virginia :thumbup:
Seem to recall a thread a couple of years back or less where freecell described the math, materials, and the physics to dissipate the current of a strike. Seems to me that CK was in that discussion too.
Funny you should ask Booty. Me and the better half just got back from a week vacation on the ocean front in RI. Granted it's not as good as Brazil but if you ask me in two days where I went, at least I'll still remember....LOL. Now to the coax. I only think this makes a difference if you're relying on the shield of the coax to carry the ground currents. This is something I do not do. Oddly enough, RG-174 might offer you more protection against lightning then any heavy duty coax since it is more likely to short out high voltages on the center conductor, to the shield.
I also don't consider one 8 foot ground rod to be an extremely good earth ground for complete lightning protection. One ground rod is likely to prevent any blue balls of fire from rolling around your radio room looking for a ground in the event of a strike, but I wouldn't count on the equipment still working after a strike if the coax were connected. Three ground rods driven into the ground in a triangle pattern at the base of the tower or mast is better. They should be at least two feet apart, driven into the ground at an angle that increases the distance between their tips in the ground and each one given a separate ground strap to the tower or mast. Then I make sure each section of mast or tower is bonded to the next one.
As has been pointed out, this still may not protect the receiver unless it's an HF rig. They usually have a small gas discharge tube right across the SO-239 connector. Otherwise the voltage spike will still take out sensitive front end transistors in the receiver. I also agree that the gamma match itself does nothing to reduce noise in the receiver. Any possible reduction in noise would be the direct result of having the radiator DC grounded to prevent static buildup. The gamma match just happens to be common with many DC grounded radiators and probably why this rumor started.
Well, FreeCell sure knew what he was talking about. His description of a quality ground covers more area then what I just went over and still he admits it's just a quick description lacking in some details. I would feel comfortable operating a station with the ground he describes.
Freecell always was good at cutting and pasting someone else's work. :lol:
http://www.qsl.net/w8wky/reference/lightning.txt
Thanks Captain. That does make a difference in the level of props he's due. His post should have included some quotation marks with that word for word copy. In any event, it's still good info.
