how to discharge giant cap
yea i went and bought one for 5$ but i didn't realize the bulb inside was 12v and it blew out lol
p.s im draining the caps with a 100ohm 10w resistor
i could go to walmart and buy a ac wall extender with 3 plugs and robb the switch from it and use the green cover from my old switch?
you know ... except from stealing it Morse I dont see why not.
All done. Just need to do the pyramid green. Found a shop called electronic expeditors in camarillo,CA the switch was $3.15 :-)
Sent from my DROIDX using Tapatalk
I would not stake my life on this....but won't a power supplies caps discharge if you unplug the unit while its running?
id say it depends. while my 14a power supply discharges after unit is unplugged, the caps inside the astron 50a Do not discharge on there own. now im sure over years of sitting they will discharge. i discharged them before replacing the switch, unscrewed the wires from the caps to the circuit board and hit them with a 100 Ω 1 W resistor a tad bit of sparking but it discharged quick and no problems.
It's surprising how few Astron power supplies have bleeders installed at the factory. I put them in my RS-35s even before I actually put them to use, and I've been satisfied with the result.
so, you stuck a resistor in parallel inside your supply. is there a good to having this benefits inside?
excuse the many questions.:biggrin:
Well for one you don't have to ask on a forum how to discharge them if you need to work on the power supply. :D :tt2:
Sorry. Couldn't resist it. :oops: If your setup is anything like mine it would be handy. My power supply feeds a distribution buss and when changing wires around it is nice to not draw any sparks if wires should touch accidentally even if the PSU is turned off. Also when unplugging the 4 gauge main buss wires I don't have to worry about them shorting out on the metal desktop or by touching a grounded piece of gear. My Tripplet PSU has a lighted AC switch as well as an LED on the output which serves as both an indicator that voltage is available at the output as well as a form of bleeder. It takes about 30 seconds to completely discharge the 25 volt 100,000 uF filter cap.
What the Captain said. I used a 1500 ohm, 5 watt resistor - and the 5 watts was because it was what I had on hand. At 14 volts applied, that's just a bit over 9 milliamperes. This in turn corresponds to 131 milliwatts, meaning a half-watt resistor would do just fine.
I could drop the resistor value down to 500 ohms. This would result in a current of 28 milliamperes and a power of 392 milliwatts, and a faster discharge time. So far, however, the 1500 ohm unit is doing what I want.
