Is This Normal?
Eastside
Well-Known Member
Apr 29, 2011
1,730
137
The lights on the xforce light up when its turned off and the 2995 is running through it?
Does not happen on my xforce, but it does on my Swan Mark II. The Swan even shows the watts thruput on the meter and any reflection noted if I switch it, all with the amp off.
What lights are you referring to, that might simplify the answering the question about 100%.
When you ask questions, be specific.
It works like a charm....puts out what they say it is supposed too.....I just noticed when I turned it off and just talked thru the radio with it still in line the lights on the front would light up a little....I do not use it....I just talk straight radio on LSB when conditions are right.....I had a nice keyboard a guy wanted and I took it on a trade. :)
I have the same radio 2995dx and the 40012 amp with modulation lights... Mine does the same thing, but I noticed if I unplug the amp and turn the power switch on, the lights will quit blinking after modulating through the mic a few times.. It doesn't affect the performance of the amp though.. Maybe it is electricity built up inside the amp??
