Everyone should keep this in mind
mackmobile43
Jock Supporter
Feb 11, 2008
6,689
418
No matter if you're a cber or a ham it applies to all
Section 301 of the Communications Act states that no person shall use or operate any apparatus for the transmission of energy or communications or signals by radio within the United States except under and in accordance with the Act and with a license. Section 95.404 of the Rules states that CB operators are not required to have individual licenses because they are authorized by this rule to operate a CB station, provided, however, that they operate the station in accordance with Subpart D of Part 95 of the Rules. Operation of CB stations in a manner that is inconsistent with the CB Rules requires a license pursuant to Section 301 of the Act. Section 95.409(a) of the Rules states that CB operators must use FCC certificated CB transmitters at their CB stations and the use of a transmitter that is not FCC certificated voids the authority to operate the station
FCC: Wireless Services: Citizens Band: Operations
"Equipment
You must use an FCC certificated CB transmitter at your CB station. You can identify an FCC certificated transmitter by the certification label placed on it by the manufacturer.
Territorial Limits
You may operate your CB unit within the territorial limits of the fifty United States, the District of Columbia, and the Caribbean and Pacific Insular areas ("U.S."). You may also operate your CB on or over any other area of the world, except within the territorial limits of areas where radio-communications are regulated by another agency of the U.S. or within the territorial limits of any foreign government. You may also be permitted to use your CB unit in Canada subject to the rules of Industry Canada. Travelers to the U.S. may operate a CB unit within the U.S. as long the unit is FCC certificated.
Linear Amplifier Ban
Users may not raise the power output of their CB units. That would be unfair to the other users sharing the channel by raising the level of radio noise. You must not attach a "linear," "linear amplifier" or any other type of power amplifier to your CB unit, Moreover, you must not modify your CB unit internally. Doing so cancels its certification and you forfeit your authorization to use it.
Antennas
There are no height restrictions for antennas mounted on vehicles or for hand-held units. For structures, the highest point of your antenna must not be more than 20 feet above the highest point of the building or tree on which it is mounted, or 60 feet above the ground. There are lower height limits if your antenna structure is located within two miles of an airport.
Ten Codes
Ten-codes are operating aids used by public safety and other professional communicators. The FCC does not regulate the meaning of the ten-codes. You may use an on-the-air pseudonym ("handle") of your choosing."
if anyone cares ...... uncle charlie doesn't seem to anymore . :D
used to have a problem with newark airport..
Thankfully the issue turned out to be on their end
( this was some 7 years ago )
