I am going to put my antron 99 70 feet in the air but i cant set my tunning rings that high up there is there any way to set it before i put it up that hi? and where would the best place to ground it be ? thanks
I go along with what the other guys said, have my A99 at 38' to the bottom and it works well no TVI. I just used the antenna as it came out of the box, used 100' of 9913 coax on my roof in the center of my lot. I use the antenna on 10-11-12 an 15 meters works great, did put up a Hy-Gain P500 at 30' to the bottom and got complaints from the woman across the street that I was getting into her Hearing impaired phone, so I took it down. that antenna did pull in distant station 30 to 35 miles a little stronger, think it had a little lower angle of radiation, that maybe why at 30' to the bottom it was getting into her phone. On the A99 I run 25w- 200w an 500w PEP output but use a LDG Pro 1000 tuner to buffer any harmonics in my signal................Oldtimer![]()
Why do you assume there are harmonics involved at all?
We usually just stick the antenna on a pole out in the yard and set the swrs, generally speaking the antenna stays good when you put her up, sometimes even the swr's get lower.
In simple terms, Thirsty has it about right. His word, sometimes, is the key word. He describes it the way it is, but it is not always so easy to achieve good results...based on other guys experiences.
An antenna match is affected by its elevation, among other things. However the change is not linear, it changes more or less in the form of a non-consistent sinuous curve.
Depending on the match condition at the start of raising it higher, will also affect the end result, so "sometimes" is a good word to describe what can happen. IMO this means such results are not predictable.
It is alway best to tune at the feed point, installed height, and location.
Here is a report I did a while back considering just this issue.
All and all, I figure the differences are so small as to make little difference, so just tune it and raise it up there.
What do you have in mind, grounding for performance or safety?
