CW Practice Key
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
So i bought this and i am not sure how to work it.... i know that headphones or as speaker hooks to where u can see two wires i have installed which is hooked to my surround sound a battery plugs in and i am not sure why i am just getting tick noises....scratchy sounds....HELP!
on the bottom is a resistor and some wires connected... nothing too complicated
Try it with nothing connected. It looks like a buzzer to me.
haha your right i just have to find the right setting "contact" oin that little screw and the thin flat metal viberates making a cool beep sound
Looks cool. I have a friend that has something real similar to that. But not exactly like it. The guy that I know that has it told me on his. You use the screw downs for hooking to your xceiver like a normal key. Then he uses his by itself as a practice key. The striker in the center makes the clicks on his it hear what u are doing. I hope that helps but I bet it don't .
73 kj4unx
73 kj4unx
Yup, my mistake I thought it beeped on a speaker. Once I buy another tranciever after I pass the general this summer ill hook it up to the new radio.
Sent from my Xoom using Tapatalk 2
73 kj4unx
here it is in action.... Japanese Practice CW keyer - YouTube
It even has that Vintage sound to it! Which ill be changing later tonight.
I believe if you disconnect that blue wire and then connect the 2 posts to your ham/cb radio you can communicate with others in the hobby.
