shack earthing bar
m3xaw
May 2, 2012
12
been sorting a way of earthing equipment in the shack made a earth bar from a bit of inch copper pipe,earth bonding clamps and a couple of pipe holder brackets.I saw this method used in a shack sometime ago but jubliee clips were used looked a bit untidy.
I would seem to think that he is going to be using that IN the shack. Shouldn't corrode inside. And then he could just run a single wire outside.
thats the way im doing it mount the earth bar on the wall out of sight behind my shack bench then run a single 10mm earth wire to a earth rod outside.
