Help with wireing a switch 110 motor
silvereagle1
174
21
28
Hi all I was not sure where to put this I hope this is ok. Here go's I have a Daytion 110 motor that will run will run forward or backward. The mod # is 6K35C and has a gear reduction box on it. I t has an on off switch on it now what I want to do is put an on off on so i can run it ether way forward or backward. I have a switch on off on to put on it. Can anyone here walk me though this Thanks God Bless.
like this I would think, but don't forget your safety grounds.
Well a pic would be nice but try this....
Motor should have 4 leads...
#1 will be a Neutral winding(possibly)white....
#2 Green(ground) same as the AC cord....(might be a screw on the frame)
You'll need to connect these first....
Now Switch: Black wire coming from cord goes to Center Pole of the ON/OFF/ON (this is the Feed from AC outlet)...
The 2 remaining leads from the motor will go to other Poles of the switch(ON Positions)....
Your sure this is a Split Pole AC 120 VOLT Motor? (forward/rev)..?
Place switch in ON Position....
Plug Cord into AC outlet...
....Does motor Run?...
Remove cord from outlet....Place switch in other direction....Place cord in wall...Does Motor run opposite Direction?....
DO NOT HANDLE THE SWITCH OR MOTOR WHEN PLUGGED TO OUTLET!!!
IT IS HOT ALWAYS!....IT CAN KILL YOU.....:oops:
If the motor works as required you will need to place the switch in a proper enclosure to safe guard yourself from electric shock...
Then Mount the motor...so you DO NOT Handle it during Operation...
And you will need a in-line fuse block between the AC Cord and the switch...This is to Protect You and the motor....
The Name Plate on the motor should have...FLA(full load amps)...
The fuse shall not be greater than 125% of this value....
EX. FLA /5amps...Fuse Size 6 amps....
Please be care...;)
All the Best
BJ
The lable on the say's to revers rotation interchange red -black. I will do my best to give you the what the lable is reading's HP/CV1/12-V 115 A-22-------------------------RPM13.5-TORQUE PAR COUPLE -350 IN LBS 39.54 N M----------------------------HZ 60-PHASE-FASE-PHASE-1-ROTATION- 127.41------------------------------------INSUL CLASS B-MAX AMB 4o C. Wires are C1= BLACK-C3=BROWN C5=ORANGE C7=RED C9=YELLOW C2= BLUE C4=NEUTRAL C6 =PURPLE C9= WHITE C10 =GREEN . There also is a relay inside the switch box that some of the wires go to. I not sure this will help or not but if not when the wife gets home i will see if we can post photo's. Thanks so much.
I will try to upload some pictures tonight!
motorpictures
Diagram of motor "Please see attachment"
View attachment 4682038.pdf
Hi all here is a wiring diagram sent to me by Granger for this motor. Plese take a look at the photo's and the Attachment and if you will tell me whitch wire gos to witch pole. My switch is on off on with 6 pole's. My power cord has 3 wires RED BLACK GREEN the motor wires RED YELLOW BLUE BLACK and the limmit switch wires are BLUE BROWN WHITE the photos show where the wires run. I can wire up cars and some in home thing's but never done anything like this. I undertsand some of it but not well enough to do it.
You should be able to use a dpdt switch, take the lead from the motor and connect to the center pole and a jumper from there across to the other center pole and connect your control wires to opposite ends of the switch.
Hopefully the picture will post... Drew it out quickly on my youngest's homework, lol. Since rotation is reversed with the connections of red and black to yellow and terminal 2, I think this is how I would wire up a DPDT switch. Not sure you have room for it in that box, you may need to mount another.
I want to thank all of you for your help with this in case it slips my mind and after 50 years on this earth that can happen :D God Bless.
