IC 7000 HM-151 mic cable problem !
VU3PYG
Mar 8, 2009
7
50
Dear All,
I have a problem with the coiled cable of HM-151, Cracks started forming along the cable and the black sheath started coming out. Very strange, i did not expect this with ICOM.
Does anyone know where i can get a replacement from ?
Thank you,
VU3PYG,
Cherry
Same problem with the mic lead on my IC7000, however it hasn't got to a bad state yet so I'll hold off buying a replacement, there's copious amounts of tape to go through before I splash the cash :D
Hello, Cherry.
I believe the mic cable is double end modular cable which is easly replaced....
Did you try eBay ?
Next I would suggest phoning 'calling' icom. I am sure they would be more than happy to link u to a site...try hamcity.com or hro
Hello, Cherry.
But STUPID expensive from Icom... Over $50 for a coiled cord with RJ45's on either end?
Mine's "sprung" (stretched) and I've yet to find a replacement for a reasonable price. I think I may try ordering one of the $20 (delivered) Icom mics from Hong Kong on Ebay, just to take the cord off of it.
Thats exactly what id do. I didnt mention a china mic because of the hardcore hams who just have to have the $80 cord ! Hihi
I had sent that seller a message a while ago asking if it was indeed a double ended RJ45 cord as pictured, but never did get a reply. The same pic also shows an ICOM logo on the back, but I seriously doubt that what they're shipping is an ICOM part...
I just rolled the $15 dice and ordered one, so I'll report back on the cable when it arrives. Stand by to stand by...
HM-133
HM133
PIN1 + 8VOLT OUTPUT ( 10 ma max )
PIN2 UP/DOWN
PIN3 + 8VOLTS IN ( No connection IC2100H )
PIN4 PTT
PIN5 MIC GROUND
PIN6 MIC
PIN7 GROUND/EARTH
PIN8 DATA IN ( No connection IC2100H )
HM-151
HM151
PIN2 UP/DOWN
PIN3 + 8VOLTS SW
PIN4 PTT
PIN5 MIC GROUND
PIN6 MIC
PIN7 GROUND/EARTH
PIN8 DATA IN
They both look the same
On the HM-133 pin1 is on the far left and pin8 on the far right
On the HM-151 it is opposite, BUT, the connector is upside down.
I would think they are the same based on that
Either way, it does not matter since you are only using the cord.
The only thing I would do is make a note of your current RJ-45 connectors and make sure as they sit side by side the wires are matched (SAME COLOR) at both ends.
Here is an extra cord I have from a Yaesu FT-817
If you look, the colors are the same left to right so it is not a crossover cord. If the Icom is the same, non crossover, then any non crossover cord will work, even a short ethernet cable.
Well the mic linked above showed up from China today...
Not only is it a double RJ45, but they're wired the same at each end as mentioned above, AND it came with a genuine (I think) "Made in Japan" Icom HM-133 mic.
:thumbup:
Problem solved...
