What is the sheild of the coax going too?? If nothing, then I would build the same elements for the sheild as well.
Mr. FX: If the fence is constructed as mine was....
20ft sections of Galv tubing...
Die cast Alum end fittings which are loosely clamped on the poles....
Then question as I did mine, the continuity from end to end is most likely pretty poor...
You might have a better shot with a wire laced onto the rail...
Later
All the Best
BJ
