6 Meter Feedline?
if it's a short run I would just use rg8x (mini)
Make that a very, very short run. Six meters is about the point where things start to take a turn as to what to use for feedlines. Without a doubt, use the very best and lowest loss feedline you can afford. On 6m RG-58 has almost 4 dB loss per 100 feet while Belden 9913 has just 1 db per 100 feet. I use Andrew LDF4-50 which has a bit less than 0.5 dB loss per 100 feet. It's not cheap but I need about 160 feet to reach the antenna so loss is a factor due to length for me.
by short I mean less than 20 feet (maybe less than 10 really)
  • @ nfsus:
    RFactive has left the room.
  • @ Tim Chambers:
  • @ AWP:
