oldslowchevy:
No; no anger nor frustration at this end - whatsoever.
Just thinking out loud - as usual.
Yes Robb, I too have seen that chart a hundred times before too. I would like to know what methods he used to determine those numbers and also just how much of it is believed simply because it exists in a nice colorfull chart. I am basing my above post on what the manufacturer recommends as well as what countless thousands of operators had success with before G3TXQ came up with his somewhat now "famous" chart.
I thought the original question was about shortening the dipole by using helical winding the dipole elements? If so, one could just buy two hamsticks and make a dipole that way. Just a simple thought.
Why don't you try 2 wilson 4' antennas rigged as a dipole with something like this mounting them.
RVD HD Dual Antenna Mount - Canada
It was indeed but somehow Robb decided to throw a curve ball and start talking about choke coils even though it was obvious to the rest of us that the OP was talking about loading the elements.
http://www.worldwidedx.com/amateur-radio-antennas/142779-yet-another-dipole-question.html#post383566
What you do not want is metal, especially a grounded object INSIDE the core of the choke. It will act as a transformer and HEAVILY couple the RF into that object which in some cases may be re-radiated. Toroids of course respond only to em fields inside the core and have a self-shielding effect from their surroundings.
Robb;383596[B said:]I would be glad to read your sources if you would link them here.[/B]
Always reading - anyway.
if i set my dipole for 11 meter for 27.185 each side has to be 8' 7-5/16" long, 17' 2-5/8" over all.
now can i shorten the over all length by coiling the leads around some pvc or a wooden dowel as long as i keep each wire at 8' 7-5/16" long, even though the whole antenna may only be 8-10' long by coiling the leads.
i really hope you understand what i mean.
You can but it will not be tuned to 27.185 any more. You cannot simply take a tuned antenna and wind part of the elements into a coil to shorten the overall length without drastically affecting the tuning. The entire antenna will need to be retuned and the impedance at resonance will no longer be 50 ohms but rather something less. The efficiency of such an antenna will also be considerably lower than a full sized antenna.
ahhhh, all part of the learning curve.
the reason behing the question was like many cb antenna that have the "load coil" like wilson and k-40 as well as many others have, were designed to shorten the antenna.
i was thinking (not always a good idea) that in theroy it could work.
If you were thinking of a choke coil; the dipole wires is NOT where it goes.
The choke coil is used on the top end of the coax - just below where the dipole wires are connected to the coax.
A choke coil for the 11m/CB band requires 5 turns of coax tightly wound together on a 4.25 inch diameter coil form.
It is just that simple - yes.
No curveball. It was that Oldslowchevy had three posts about his ailing dipole in the last two days alone. Thought I would air it out and see if we could find out what the problems were. He never mentioned that he had a choke on it before now.
The above are the first posts in this thread.The "leads" he is referring to are the element wires themselves and not the feedline.That is the only way the element would be shortened. Making a choke at the feedpoint from coaxial cable would not shorten the elements to half size as he said.My point was that he never mentioned anything about choke coils in his posts before you started talking about them. It was clear in his first post he was talking about loading of the elements by coiling the element wire. Somehow it lead to you discussing choke coils. Am I being picky and refusing to give in on this? Hell yeah!! I have had about 10 hours sleep since 9:00am Wednesday morning, about 105 hours ago, and I have had just enough coffee and sugary icy freezies to push me over the top to somewhere between a total wreck and a jittery madman. :blink: Time to go grab a single Mike's hard lemonade and get plastered.![]()
