Running two power supply's parallel.
reddog45
Jun 13, 2011
56
Will this work? I have two pyramid 50 amp supply's. just curious if they will work in parallel.
Sent from my iPhone using Tapatalk.
45, North Florida
The supplies should have come with some sort of operator's manual to tell you whether you can do this or not. Some Astrons have provision for it, but I'm not aware of Pyramids being able to.
You might contact the company...
So they worked well together Charlie Brown? No voltage drops or anything?
45, North Florida
If both supplies are of the same make and model and have the same voltage output then you can generally run them in parallel without an issue.Ideally you should have an isolation diode between them but it is not 100% necessary. Do NOT even think about using unregulated supplies in parallel however. Been there, tried that, saw the havoc it created, gave up on it. :biggrin:
Ive also ran 2 Pyramid PS52K supplies together without a problem just MAKESURE THE VOLTAGE IS SET THE SAME ON BOTH SUPPLIES. I also have metal lugs (Astron style) on the main supplies negative and positive because of the plastic knobs melting.
