108.8 and 115.8mhz AM
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
I know this belongs in the airband section but I'm curious as to why there is the same cw signal on both those freqs and it's only transmitting cq cq. Every 30sec
115.8 MHz is a VOR nav beacon in California. The callsign is CMA which could be confused as CQ by running the letters M and A together.
CQ = _._. _ _ . _
CMA = _._. _ _ ._
CMACAMARILLO VOR/DME
CAMARILLO, CA
Location
Lat/Long: 34-12-45.082N / 119-05-39.678W (34.2125228/-119.0943550) Elevation: 63.0 ft. Variation: 15E (1980) Operational Characteristics
Type: VOR/DME Class: L-VORW/DME Frequency: 115.80 TACAN channel: 105X Altitude code: L (low) Hours of operation: 24 Voice ID: no Morse ID: -.-. -- .- NOTAM facility: CMA FSS: FSS hours of operation: 24 Technical Characteristics
Accuracy: NOS Monitoring: Internal monitoring plus status indicator at control point Owner: FEDERAL AVIATION ADMIN Operator: FEDERAL AVIATION ADMIN Common system usage: yes For public use: yes Remarks
  1. 3RD PARTY SURVEY DATED 25 OCT 2010.
  2. VOR/DME UNMON WHEN FSS CLSD.
  3. VOR/DME UNUSBL 301-045 ALL DIST ALL ALTS; 046-245 BYD 20 NM BLO 14,000 FT; 276-300 BYD 20 NM BLO 14,000 FT.
CQ = _._. _ _ . _
CMA = _._. _ _ ._
CAMARILLO, CA
Location
Look at you go ! Correct. I called a friend at camarillo airport to clarify what i was hearing
Google is my friend. :thumbup1:
I just didn't (and still don't) know what your post was about. were you trying to say that Google will now search websites for a specific image I want to find? A bit useless if I already have the image. :laugh:
    boog351 has left the room.
