Cobra 29 chrome talkback volume
I did notice after doing this mod, if you crank the talk back all the way up, the radio will lose some swing. I don't under stand why, unless running the talk back wide open causes a drop in voltage maybe?
its robing audio from your output.
Yes this is what I did. I don't remember the numbers now, but say it was swinging to 30, and when the tb is cranked all the way it will only swing to 25. In fact I injected a tone, and watched the meter as I turned up the talk back volume, as I turned it up the meter went down. No coincidence.
