Really bad luck with alignments, or...?
Not at all really. I have a Magnum Delta Force and in LSB mode RV108 is the VR frequency adjustment. After a recent alignment by a qualified tech I was told the radio was a tad off. RV108 was very very touchy, you turn it a smidge of a hair and it would change the tx freq enough for people I talk to to notice.
After we got it all set I was curious so I lifted the radio about 2 inches above the towel covered table I was working on dropped it. This slight bump would be about like hitting a medium size pot hole in the mobile. When I keyed up everyone right away said that the radio was off frequency again.
So sorry bud but the way UPS and Fed Ex toss boxes around that it very much a possibility. Heck the radio might even have an issue, DTB is a trusted tech and it is a Galaxy radio.
My experience is that those pots are touchy, but should not readjust themselves from the radio being jarred.
I supspect that might be symptomatic of a pot that is defective with regards to its mechanical stability and if replaced then that symptom might go away.
A former coworker took his new Cobra 29 LX in for a clip and snip job. That radio would move back and forth off frequency bad enough to notice it on AM. All depending on how rough the road was. The hackmaster who laid his golden screwdriver upon that radio told him it was junk and he should buy a new radio.
He ended up sending it off, the adjustment pot was replaced and the radio was un-hacked. The pot was so loose that they said they could jiggle the radio and it would turn.
I might can realign my 959 to my 8900 then. I haven't sent it back to DTB for a realignment after my Star Electronics bought and DTB installed and aligned Viagra board came crashing down. I can zero beat my MFJ-207 to my 8900 and maybe align the 959 to the 207(don't bump the dial)
I don't advocate this tuning method. I posted for anecdotal content. Do this ghetto tune at your own risk.
It will work close enough for government use.
Yes, it will get ya close. But it is highly dependent on the quality of the radio you are tuning it to. If that radio is also out of adjustment slightly; then so will the radio you are tuning. But it will work in a pinch.
The real trick is to get that 'whoop whoop whoop' to slow way down. If you can get it to go 'whhhhhhhhhhoooooooooooooooop' - and then stop; then you are even closer to tune.
This thread has officially degenerated to a level that is lower than worm poop.
OK OK; will try to pick it up a notch . . .
This 'whooop whooooop' tuning method is just a temporary means to get the radio reasonably back on TX freq. Sorry about that.
In a real alignment the VCO voltage and output signals are set and peaked respectively. Then the Loop Oscillators are tuned for proper freq on AM/USB/LSB. Once this is done; then the TX Offset freq is set. Lastly, the Output Oscillators are tuned for AM/LSB/USB.
Using an accurate freq counter is essential for best results. Using the 'whooop' method doesn't take into account that at any one of those adjustment may also be off. They need to be done to place the SSB envelopes position correctly in relationship to the AM carrier to keep the radio's RX/TX consistent. Doing this process by ear can NEVER accomplish this end. Just used in a pinch - is fine. Besides, there well may be something wrong with that radio - even if it is new.
That's much better.
Thank you.
Got it lined up to a fellow local's radio over the air. We'll see how long it holds and if I can get more reports later this week, thanks for the advice guys! (y)
    63Sprint has left the room.
