I have contacted some one from a email address that was on my packaging when I purchased the predator .
He has said the coil has to be 4" above the roof. My antenna has 2 coils still under the roof line . View attachment 9485
I saw some where on the net. Where a guy made a shaft from a pice of copper tubbing. Will this work ? I mean just making the bottom shaft longer .
Tell Kale you need a 27" lower shaft.
The way the coil is machined it is not 3/8-24 top and bottom, and it would be stronger the way he makes them in the long run than Copper tubing.
Kale is a good machinist.
I agree with everyone else. Extending the bracket is a bad idea. I run the 27 inch single coil in same exact spot you have yours mounted. Mine tuned down to 1.2ish pretty much all across 11m band. I was a little scared of the long shaft length, but mine has been holding up fine. My truck has 3 inch lift and I've already smacked a few limbs and low ceilings on drive thrus with the 10k whip. Hasnt bothered it at all!
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
