Here is my New vs. Old Top One antennas and the Old with a full 1/4 wave as the top element.
View attachment New Top One vs. Old Top One.pdf
YouTube - Marconi's New Top One vs. Old Top One full length 1/4 wave radiator
The things I see different are the New Top One has a wider bandwidth, a better match at the middle of the CB band, and the RX is quieter and the clarity is often better in many cases. On some occasions I can get a better copy of a particular signal in the distance on the New Top One. This may be due however to a slight difference in the typical noise level between my two mounts with one being closer to my electrical service out back. The other day when I first mounted the NTO I wasn't able to get it mounted quite as high as the OTO, it was a few feet lower. The advantage was obviously in favor of the OTO, but since then I've raised the NTO up about 2.5' feet more and now, according to my Signal Reports, both antennas respond about the same.
