Icom ID-51 Official MARS Expanded TX & RX Mod
Ham Radio Nerd
Apr 14, 2002
9,350
2,063
383
Here is the official modification to expand both the TX and RX capabilities of the Icom ID-51:
RX frequency expansion
A BAND
VHF: Expanded frequency range: 137.000‐174.000MHz. (FM/FMN/DV)
UHF: Expanded frequency range: 380.000‐479.000MHz. (FM/FMN/DV)
B BAND
VHF: Expanded frequency range: 108.000‐136.995MHz. (AM), 137.000‐174.000MHz. (FM)
UHF: Expanded frequency range: 380.000‐479.000MHz. (FM)
Remove D9 on Logic board.
TX frequency expansion
UHF: Expanded frequency range: 400.000‐479.000MHz. (FM/FMN/DV)
Remove D11 on Logic board for VHF band.
Remove D10 on Logic board for UHF band.
See the attached PDF for locations of the referenced diodes.
Reactions: SPQR
Gonna regret asking this since its right in my face but, to be absolutely positive: even w the mod, there's no way to scan the 480s on the 51, right?
Having a trouble with PC Software.
Hi. I have apply this mod to my id-51e and have a trouble with Cloning software(Rev 1.02). If saving on my radio expanded freq and save config to SD, and load config from SD - all working good. But if I opening this file in cloning software expanded freq with yellow triangle and if I trying save it programm give me message "Warning: error setteing found. Correct?" If I push YES this setting removing and I can upload this file in radio without expanded freq. If I push NO I can't upload this file in radio and see error message on my radio.
What can I do?
The mod I posted is for the U.S. version; I can't verify how well it works for the European version of the radio.
I tried it on a ID-51A and it is doing the same thing as the earlier comments (adds yellow triangle). Any ideas?
Are you trying to write the frequencies to a file on the MicroSD card or using a programming cable? I just verified that I have no problem writing out of band frequencies to the memory card.
A BAND
B BAND
Thank you Moleculo! I'm comparing 51A Plus and FT2D, do you know the Official MARS Expanded TX & RX Mod can also be applied on 51A Plus? If so, I will buy ICOM ID-51A Plus, thanks again.
Hello,
I have got the same Problem, I can TX out of band (in a dummyload ;-) ) but I can not store any qrg out of band. My dealer metioned to try the IC-51 plus cloning Software, but this one does not work for my ID-51E.
Has anybody found a solution for this Problem?
74 de
OE5MMM
    boog351 has left the room.
