Here are the specs for this radio:
Price: $412.00 shipped to you
Product introduction: this section KN920 shortwave radio specifically for amateur radio development, because of advanced humanized design, cheap price, it's easy to learn to fit at the same time, so is well received by industry the lovers. This paragraph in shortwave radio multichannel transceiver, various work modes, internal circuit and high-speed microcontroller computing storage frequency, control tuning. LCD screen visual display parameters, users can very convenient manual input, storage, frequency, switch mode, etc. The fuselage panels with handles on both sides, is very appropriate also carry radio field to communicate. At the back of the fuselage with a cooling fan, cooling operation during launch.
Receive frequency range:
30 KHz to 29.999999 MHz
Range of transmitting frequency:
3.500 3.9999 MHz
7.000 7.300 MHz
10.100 10.150 MHz
14.000 14.350 MHz
18.068 18.168 MHz
21.000 21.450 MHz
24.890 24.990 MHz
28.000 29.700 MHz
Work mode: SSB, the CW, FM, AM (AM just receive in use).
Storage channel: 100
Transmission power: 1-10 w continuous adjustable (can be adjusted within upper limit, maximum set to 20 w)
LCD screen display: frequency; Power; Working mode; Receive field table; Launch parameters such as standing wave
Power supply: receive: 13.8 v / 0.7 A; Launch: 13.8 v / 4 a
Antenna interface: M
Size: 230 x230x90mm
After packing weight: 3.5 KG
Launch unit circuit structure:
SSB/frequency superheterodyne the CW is 2 times
FM frequency superheterodyne three times
Spurious emission suppression: better than 40 db
Carrier suppression: better than 40 db
Receiver unit circuit structure:
SSB/the CW/frequency superheterodyne AM for 2 times
45 MHZ SSB/the CW/AM a intermediate frequency:; Second intermediate frequency: 12 MHZ, 3 intermediate frequency, 455 KHZ for FM
Sensitivity:
SSB/the CW: 0.2 uV / 10 db; AM: 1 uv / 10 db
FM: 0.2 uV
Selective: standard 2.4 KHZ / 6 db SSB mode; 3.6 KHZ / 40 db; AM mode 6 KHZ; The CW continuous tunable bandpass 200 ~ 1200 hz
Mirror phase interference suppression: - 70 db
Attachment: the host a, one hand microphones
Note: this product is a new shortwave radio, because less inventory every time a reservation, please to shoot after communication with the seller, thank you for your cooperation.
Aliexpress.com : Buy Whole ham kn920 kn 920 utrashort wave ham radio station equipment shiortwave SW free shipping on Healthy environmental protection technology co., LTD.
3.500 3.9999 MHz
7.000 7.300 MHz
10.100 10.150 MHz
14.000 14.350 MHz
18.068 18.168 MHz
21.000 21.450 MHz
24.890 24.990 MHz
28.000 29.700 MHz
Size: 230 x230x90mm
Sensitivity:
FM: 0.2 uV
