anytone5555 v6
jonnyshoot
Jul 17, 2013
3
Hi im new to all this?
So i started with a AnyTone5555 v6 works well:D BUT when i put a small amp on to it, it reads in the display 5 HI with a hi pitch noise:(
Any one know how to fix the problem with out getting rid of the rig:pop:
Thanks
JD:pop:
Use the software and turn off the hi SWR alarm.
At the same time, turn the warning to the maximum amount possible (as well as dissabling the hi swr alert) The noise should stop and radio will keep transmitting but you may still see the warning flash on the screen but it will not affect the transmission
If it is reading a SWR of 5; then perhaps you might want to heed that as a WARNING?
Might be wise to inspect your coax jumper or run it w/o the amp until you find the problem?
do all that ,then check swr with external meter or antenna anylizer
