Retevis is giving away THREE radios for their 16th Anniversary! Click Here to enter!
Needle swings backwards, power is too low to calibrate SWR meter and scratchy audio
I had this it was the TX signal meter VR, variable resistor like a silver horseshoe, you need to find yours on a schematic.....also the RX signal VR was out.....I actually did mine with the rig upside down and set the needle to the right, when I turned the rig right way the needle was going to the left!....had to do it all again...
