5/10 turn pot cobra 142 gtl
KD2GOE
May 30, 2013
952
220
173
45
Buffalo
where can I get a 5 0r 10 turn pot for the clarifier on a cobra 142GTL I would like it to except the stock knob any one have a part number or a link?
Thanks
Maybe Tim @ SR Customs can steer you or if ya catch him when he isnt crabby he could sell you one. Ive seen one of his recent vids and he blurrted out where he gets those 10 turn pots. Gotta listen to him carefully cause he sometimes says his suppliers.
you can get them from Mouser electronics, and im sure others carry them too.
mouser does not have a minimum order, thats why i chose to link to them:
534-11203 Vishay / Spectrol | Mouser
this is the one you want.
you will find that you will have to carefully drill out the inside of the knob just a little bit.
you should use a 1/4" drill bit.
here is the technique i use.
use a drill press, and drill a hole in a block of wood that will allow the knob to be placed in it, hole side up.
the knobs are usually tapered, so its easy to just push it in and it will stay put.
make sure you get it lined up right, as you dont want to drill off angle.
set the stop on your drill press so that you cant come through the other side of the knob, and slowly bore out the hole to exactly 1/4".
if done right, the knob should push right on to the shaft of the 10 turn pot with a nice and snug fit.
you should also be able to pull it off later without damaging the pot.
yes, you can just use a hand drill, but after a few knobs that look "wonky" when you turn the clarifier, you will want to do it right.
i understand if you just got frustrated and restored the radio to stock, but an unlocked clarifier is very helpful when trying to talk to more than one person on a channel.
good luck,
@ loosecannon. The main reason is it slides way to much I don't mined the unlocked clarifier just don't want it to slid so much..
First off, unless the radio's clarifier is unlocked AND it can slide 10-20kc's; then there is no point to put in a 5-10-turn clarifier pot. The basic open clarifier mod does not slide more than 1.5kc's and the stock pot is just fine with that.
If you REVERSE the open clarifier mod; then it will be necessary to RETUNE the radio loop oscillator. So, I would not do that unless you are prepared to have that done too.
I have a high rez frequency bench top counter.
So an alignment will be ok. I did it on my RCI and Uniden Washington..people tell me I am on freak.. it has xtra channels will that change how it is aligned ?
the extra channels wont change what freqs you set the VCO offesets and IF cans to, but it does change where your "center" freq is, and that means that when balancing the RX and TX sections for even spread across the band, you might use a freq higher than 40 or lower than 1.
it depends on what your specific coverage is.
on the clarifier mod, the way they did it is kinda dumb.
remove the orange wire from those resistors and such and put it on pin 1 of the MB3756 voltage reg.
remove the red wire from PC board ground and insert a 3.3k resistor in series with it.
you will have to re-align the VCO offsets, but this should tame down the slide a bit.
that is 100% what I was thinking LOL
tapping off the 13.8V rail is not smart as it is not regulated as good as tapping off the MB3756 voltage reg.. if the voltage where to drift it would make the clarifier drift.... am I right?
that fixed it good I did not need to add the resistor or even realign it and it is much more manageable. it even put it back on the center slot LOL!
I thanks you for your help..
glad to help.
yes, if the voltage fluctuates, so will your frequency.
usually a 1k resistor will drop 13.8 volts down to around 8 volts.
if those resistors (remember they are in parallel) equal less than 1K, then they were trying to feed too much voltage to the clarifier in order to get more slide.
a true cheap and dirty trick.
you will still love the 10 turn pot.
makes any radio more stable on SSB.
glad to help.
yeah he had 2 100ohm in parallel :headbang
here it is now after I fixed the wire
