static build up
And what are you going to ignite?
You're talking an internal combustion engine, in an ambient atmosphere...not exactly working in an intrinsically safe environment. No different than the fool on bald tires with the belts showing driving past you on the highway...or the guy (like me) with studded snow tires.
Let's be realistic here...there are worse things to worry about if you're getting to the LEL or UEL when out on the open road (in other words, you're likely already dead).
Get my point?
I do not know where you live, but out here due to being so dry we still have a very high fire danger.
What will ignite?
Try dead dry grass.
I have seen guys dragging safety chains start fires on the side of the road, not uncommon during the middle of hot dry summers.
For Grins, go take a look at most manufactured Antistat straps for sale.
Thanks. So if I look at the two wires in that circuit is there a way to tell which one's hot?
I do a basic wiring book
Touch one and see. You will immediately know which one is the hot wire. :D
NEC code dictates that the ground wire is either bare or green. The neutral wire is always white and the hot wire is the black (usually) or it could be red or possibly blue (rarely).
What will ignite?
Try dead dry grass.
While we have a wetter climate around here, I had that cable deal all over the US...over 200k on the last truck alone. If you think about it, its floating in the air most of the time anyway. Maybe mine didn't touch that much? Never had anyone tell me it was sparking...I would think a truck driver would have said something the amount of miles I put on the interstate system.
As I said before, I went through a lot of the straps because they would freeze to the slop in the driveway...they would rip off the crossmember when you started to drive away.
Well if they rip off your cross member I wouldn't do that
Again!
And thanks again for your thoughts and ideas on this
Problem of mine.
I'm going to have to find someone who knows how to do
All of this so they can go over it with me. so I can pick
Their brains and learn some more so I can do my own
Work on my radios!
