Galaxy 2527 no RX no TX
Charlie Brown
certifiable
Dec 18, 2010
344
66
Tennessee
www.pedalsteelman.com
Have a problem with the 2527. No RX & no TX. The radio meter shows its keying up but the modulation meter shows no modulation and also theres nothing on the watt meter? Talk back even works but still no TX on the watt meter. No ears just some static? WHere to start?
since you do not have TX or RX the 1st thing I would check is make sure the PLL is in lock. if it goes out of lock from the vco voltage being off will cause the issue you are having.
