well its took me a while but i just got a new"less than yr old" rci 2995dx with the green digital face..sadly it came from a good friend that passed away last yr so i traded his brother out of it..got about 400 into it so not too bad..
decided after reading for 2 nights to install a switch in the amp section for lower watts as i talk to guys in my n.hood thats real close and also dont wanna start over just yet with new amps..i like my ole tube amp that i hardly ever use.
really have no need for a amp with this radio either..it walks the dog..
i read that on the older 2995dx units folks says they run the switch on a brown wire that plugs into the back amp circut board in the right corner..i have a small plug there but its yellow and green wires..
the new mean well power supplys have a row of wires on the end and all labeled so i used the red"hot "wire coming from the p.supply going to the amp and switched it in that wire. IS THIS OK ?
im asking because i just finished it up and everything is working fine with it on,but dont wanna turn it off till i no for sure why folks say use the small plug on the board to install the switch? they say this about the older ones far as i been reading..
so me cutting the power at the main hot lead to the amp should be the best thing to do id think..comments welcome,except how 4 watts is the limit and im an outlaw<can not stand it> the first pic,red wire on the left it the one i used,and i fused it also with 20 amp fuse and used 25 amp switch..had to use a white wire as i was out of red thanks,and heres some pics of the radio and switch install,j9
