ALM BUTTON?
I went to go look for info on that radio and found a new mic that will fit it if he wants one. I also found a NIB 77-115 on Ebay that is expandable frequency wise. I didn't find anything on the 77-117.
its a 77 117 it has ch 9 switch on the wx ch selector. and a cb/wx switch
and this ALM button but if u press it when in cb mode it seems to do nothing
if u press it when in wx mode it seems to silence the wx broadcast
also if you are in wx mode it seems the ch 9 switch which is on the rotary wx ch switch is now not ch9 but another wx ch.
i actually only bought it to see if i could remove the wx system to install in a multi block ssb compact rig but it seems to work pretty well and is a neat size with up/down ch on the mic ( making that mic in the link not much use)
It's not about quantity but rather quality. Besides I can delete more posts than that in a day. :laugh:
I was going to respond to his comment by pointing out that some post seldom, but say a lot. Most post regularly and make up the crowd noise. And others post just to take up bandwidth.
But I didn't so I'll take your lead.
triple5usb,I was simply pointing out an alternative by suggesting the Pocket WX radio but if that's what you're trying to do then go for it.
