I just got that VF from a website that had several listed.I think the RG11 Velocity Factor is closer to 66%.
If it is, then the length of the 75 Ohm transformer would be 5.9675' or 5' 11-5/8" - yet shorter than before.
Belden's RG11 has an 84% "nominal velocity of progation"... Nothing anywhere close to 66% or 75%. You guys have any sources for those?
Data Sheet from belden.com.
I've seen others between 82% and 85% as well... Nothing anywhere close to 66% or 75%. You guys have any sources for those?
The DB
Coaxial cable velocity factor information
I just buy the 6' 75 Ohm cables, put adaptors on each end, and enjoy my match. I center on 27.385 MHz
Nope, Nothing wrong with using it. I have.What? You BUY your matching sections? The king of making stuff outta other stuff??? :tongue:
I have a bunch of 75 ohm cable laying in my attic from previousl cable/dish installs. Anything wrong with using it?
73,
Brett
No I didn't. When I decided to get rid of the yagi and do the quad, I went straight for the 4 element direct fed design.359 i have to ask..love the 4 elem quad in your avatar..wondering if youve had a 2 and 3 element before and if the 4th really does much more then the 3 ?
j9
I didn't take any pics before I put it up, but the tension of the wire element goes to the plastic block, not the coax. The element and coax both attach at the same point on the plastic block. It's been up a few years now with no stretching.yours looks real nice but seems the wire pullin on it at an angle would make it relax and strectch a lil..got better pics with it hooked to the wire?
I'm sure it'll work, it's just extra parts and extra weight that's not really needed imo.my neighbor has 2 quads and they have a similar thing i made iirc..
Yep, that'll be vertical. I prefer the diamond over the square so the connection is as a spreader and not unsupported in the center of a wire run.his horizontal is square and it hangs in the middle of the wire.
i was gonna put mine in diamand shape like yours and the connector on the west end spreader bar.? what ya think.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
