SUPER-SIZE MOBILE MOUNT!
Roger That
Mar 4, 2014
26
5
13
Parts Unknown
I was looking at new and different antenna mounts for my mobile when I stumbled across this monstrosity:
New 4 Magnet Super Mag Antenna Heavy Duty Quad Mount for CB Ham Radio Antennas | eBay
Looks like you'd need two people to effectively R&R this beast! Probably could get away with only two magnets, but four?? Are you driving around with an A-99 base station antenna? LoL
It gives me a Polar Vortex wintertime cabin fever project idea similar to this, only with two 5" magnets underneath a 102" whip
I bought a small box of stuff one time with a cobra 2000 d104 desk mic realistic desk mic and a speaker.and a mobile antenna. $150 cdn :p.not bad if ya ask me. I was surprised at the antenna that was in this.
One magnet. Same size as those in the picture. And a 7 ft firestick trucker style antenna. Im like wth who would drive around with that. Still not sure to this day. I however used it as a base antenna on the roof of my apt. Surprisingly it did pretty good. Even broke skip on the superbowl ch 6 with no power straight stock.
To this day I wonder who would need one that big with a single antenna let alone 4 magnets.
It seems you would do a lot of paint damage to the roof yanking that thing off and putting it back on. If someone needs a magnet mount that large, drill a hole.
Wouldnt having more magnet surface area improve the RF ground coupling to the sheet metel? I figured it would, but I dont know. This might be worth researching.
I'm curious , yes why not ? It has more metal so it should increase the ground plane effect , even if by a small amount .
Sent from my NB09 using Tapatalk
why take it off at all? with the right antenna this thing will shear through tree branches and low overpasses.
it's been a while, but I do recall being impressed when i took mine down after a year and a half. there was significantly less discoloration than I'd come to expect from a wilson 500 running the same output.
It may not supply a better ground plane, but it does distribute the flow somewhat.
I will concede that you might get an ever so slight increase in so called ground-plane but not worth the effort. There many variables in this as well, how its constructed, thickness of the metal, position on the vehicle and so on.
    boog351 has left the room.
