A Winner has been chosen for the 2026 July 4th Retevis RA89R Giveaway! Click Here to see who won!
For some reason my 2527 sounds crispy, crackly, and distorted on SSB. Almost like the AGC has been cranked all the way open. Anyone have any hints for me?
D1, D2, D34, D35 replace with 1n6263 diodes. this is for the old 2950 radios.you said yours has this board in it. before I did much to it I would make sure it is aligned properly. since you say it is only on SSB
Did that 'mushy' condition come on suddenly, or has it always been that way?
If it happened suddenly, then a part may be failing.
If it has always sounded that way, it would be best to ship it off to a real tech and give the radio a complete alignment.
Any radio will always operate better in TX and RX when properly aligned.
That diode changeout - while beneficial - will not cure the problem.
