DX99V2 Questions
MrKenmore
New Member
Dec 4, 2013
4
I have been looking at the DX99V2 for a while. When a reputable shop does the peak and tune and frequency conversion, what 10 meter frequencies are lost? I have a CRE8900 which is very flexible and doesn't lose anything. I am more into 10 meter now and only want 11 meter to listen to.
Thanks!
Sent from my DROID RAZR HD using Tapatalk
If your mostly on 10 meters wouldn't it be better to get a radio with a VFO or continuous tune like the 2950. you can also use it to to tune as a channel 1 thru 40 type radio also. not that the Galaxy isn't a good radio.
Reactions: 2 people
I had one when they first came out. I liked it, but I like my Galaxy DX-94HP even better. Gives me a tickle.
So how does the receive on the 94hp compare to a 2950 in your opinion? I may be crazy, but I think the receive on my 959 is better than my 2950. Thx.
Purely subjective, but...
Not much difference. My 94 seems to have less noise than a 2950.
However, if I could only own one radio, I'd buy the 2950 because of it's feature set.
I second this, skip the export and go straight to the real HF radio.
Well I broke down and bought a 99v2 the other day and I must say I like the radio so far. I haven't gotten it aligned yet but it seems to function properly stock. It also seems to be a more quality build than an 949/959 which has been the extent of my experience with Galaxy radios prior to this one. Also looks higher quality/cleaner built "under the hood" than the Mag S45HP I have.
More stable than the 959 I currently have, 65-85 degree temp swing in the truck and very little freq drift. Time will tell if it drifts more in 100 degree heat.
A damn fine looking radio to boot.
