A Imax 2k new out of the box has the swr set at a 1.5 this is with the rings in the center of the black section....
To fine tune it, both rings needed to be a little lower in the black, that would have gave u a 1.1 swr or less across the 11m band....Forgot to mention I tuned mine on channel 20....
And on the 10m band up around 28.3250 to 28.500 the swr would have been a 1.3 swr....this is what mine was running 3 years ago when I bought it new, and now on the 11m band swr is a 1.1 or less.....oh yea, and Im running 62ft of RG 213 coax on it..
Tuned my swr the ol fashion way I guess, didnt use a MFJ meter..
Oatmeal, in 2009 a friend loaned me an Imax to test using my Autek VA1 analyzer. The antenna was old, but it was brand new in the box and had never been opened. At the time we were hearing stories that Solarcon had changed the resonant point for the Imax a bit higher...in order to help encourage more 10 meter use here in the US. Other CB operators had been suggesting a difference in length between an Old Imax and a New Imax. I'm not sure this "CHANGE" ever happened though.
As best I can recall we wanted to see if I could tell by doing a bandwidth report, using my VA1, if the claim from Solarcon was true...about their factory setting the tune for use in the CB band at 27.205 mhz like the manual indicates, and if the sweet spot frequency was higher than reported in the manual.
We also wanted to see if I could tell the frequency difference that a 1/4 turn of the rings made to the resonance of the Imax, and if possible how many channels a 1/4 turn made in the process. I never tested beyond this single iteration however.
The Antenna Work Sheet form I used in this case covers a bit more that the CB range only, the frequency step rate is equivalent to 5 channels, and the top curve is results from the VA1 at the antenna feed point, and the bottom line was read thru a working feed line to a Daiwa CN-801H a foot away from the radio.
Here are the two BW curves before and after, moving the rings down 1/4 turn.
View attachment Imax VA1 test.pdf
IMO these reports clearly show the Imax is higher in resonant frequency than Solarcon suggested (27.205) in the manual, and the Z value for the complex impedance is right on the mark near 50 ohms across the entire CB bandwidth. Make you own conclusions about what this tells us.
The data also suggest that the Solarcon matcher is very effective at controlling the resistance (value of R) across the CB bandwidth and for me that is what makes this one so broad banded.
In the real world however, your results may differ.
